Anti-Skid Service Required / 2011 C30 Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Has thanked: 1839 times
Been thanked: 1709 times
Re: Anti-Skid Service Required / 2011 C30
Then the other option is to center the unit and have the alignment shop adjust the outer tie-rods to set the wheel straight the the centered steering wheel.
If the centering/alignment of the steering column and the clockspring are way off, you may have to center the rack, lock it and then separate the rack from the column and refit with the clockspring centered.
Hope that makes sense.
Pretribrapper
Year and Model: 2011 C30 2.0 T5
Has thanked: 51 times
Been thanked: 6 times
Post by Pretribrapper »
I actually bought a used clockspring off ebay that guaranteed to work and I tried to center it and still same message. Using icarsoft to reset it would not reset the Steering angle. Kept saying failed. Two of the other 3 sensors it did reset but still same message. I am buying a new steering angle sensor that has the retaining screw in it in the right spot so hopefully that will do the trick. Thanks again for all the insight.
I wish you luck on this. If you did not have an issue when you started then it is something that has been disturbed while working on it unfortunately. You did run the steering while running from lock to lock to calibrate it?
Pretribrapper
I have run this from lock to lock and even installed another sensor and still can't get the light off. My icarsoft cr max bt device is unable to reset the light.
Do you actually get an OBD2 code for this issue or just that message?
Pretribrapper
I just get that message. There is a steering angle sensor code that shows up but I forget what code
Pretribrapper
Quick update... I uploaded my diagnosyic scan to the icarsoft team and they said that I need to reset the Steering angle sensor through the brake control module.. Will try tomorrow and follow up
Pretribrapper
All fixed. I was off by a single rotation. My icarsoft device gave me live steering data and I learned that I had to reset the dstc in the Anti Lock brake function as opposed to Steering Angle Sensor function. When I went to ABS function on my scanner I reset the steering angle faults there and everything zeroed out. I then went to the live data and saw the angle at zero. As soon as I turned the wheel slightly the number changed to 361° which showed me I was still off by one rotation. Turning the wheel to the right the number went down so I pulled the steering wheel off and did one full turn on thw sensor to the right. I reattached everything and took it on a ride. Everything is perfect now. Thanks again
