Question on Blower/Resistor
- Has thanked: 1506 times
- Been thanked: 3819 times
Re: Question on Blower/Resistor
Ii bite on this one. I’m guessing running backwards runs on the high ridge on worn brushes which will work for a short time, then will fail again. Time for a new motor
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 47 times
- Been thanked: 44 times
You are correct - I removed the mounting cover. The motor housing has a decent amount of dust as a result of brush wear.
Part is on order...
Part is on order...
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Grantkat
follow up - New fan arrived, installed and I once again have air flow - significantly better than before I might add.
High five to the Volvo engineer who placed the fan where it was and made it so easy to swap out. I have done fan replacements which took an entire day because you have to practically pull the entire dash to do it.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
