What did you do on your P1 Volvo today? Topic is solved
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Was under the car to replace the control arms and track down some axle issues (pulling to the right). Control arm replacement went fine but I noticed one of the bolts on carrier bearing bracket was missing. Popped off the bracket cover and all the balls bearings fell out.
Turns out the lower bolt actually sheared off, and the axle carrier bearing ended up crooked In the bracket. I'm thinking the bolt was stretched already and when my friend hit a gnarly pothole with the front right wheel it caused enough trauma to pop that bolt and walk the bearing crooked.
For now I used an in-stock axle that Orielly's had, doesn't seem like there's a high quality t5 m66 AWD axle available anywhere so might have to send my original out for a quality rebuild. And when I do I'll replace the bracket as well.
07 V50 T5 AWD M66 ~146k miles
Has thanked: 2209 times
Been thanked: 1852 times
Wow, those that carrier bearing has been one for far too long for sure! I've had them get noisy, but never had one go out like that on me. You were lucky!
Today was the 06/08 V50 T5 AWD manual day. Young owner had new O2 sensors to replace and the RH engine mount to try to fix a clunking he is getting from the RHS front. He splashed out for a new Volvo OE part. Removing the old one I could not see anything wrong with it. I think it was a Meyle branded one we fitted last year. Fitted the new OE one but unfortunately the issue is still there. Some proper diagnostics this time!!
He also wanted to swap the O2 sensors. Pointless exercise as the turbo to downpipe is loose, but he wanted to do it anyway. Not too terrible on a P1 but good job he is young and flexible! :lol:
Sure enough, no improvement............
We will have to remove a bunch of stuff to access the turbo from below, probably including the angle gear. I think the owner believes the studs have stripped out.
smacknab
Post by smacknab »
scot850 wrote: 04 Mar 2026, 18:53 Pointless exercise as the turbo to downpipe is loose, but he wanted to do it anyway.
I have a whole thread about diving head first into fixing a problem before I truly understood it. On many occasions I was shooting the parts-cannon at my first Volvo thinking I was fixing things only to find my time and money would've been better spent elsewhere on the car. Perhaps you can have him read through it and see if he learns from my mistakes 😅. It's not a bad way to build wrenching confidence which can pay dividends with both the car itself and in life at large (I can draw a line between doing a head gasket following RobertDIYs write up and building my own heated floors at my house). However I'm curious if you feel that the lessons about the importance of proper research and diagnosis are sinking in with him.
Just wondering because I'm also trying to find the best approach with my little brother. He recently bought his first older European car and I see him falling into familiar traps- an oil leak might likely be the rear main seal or a rattle at x RPM might mean it needs a timing chain. I'm eager to help him wrench and learn the hard earned lessons, however my advice has been he should pay for a proper full inspection at the euro specialty shop with the experienced mechanics that the car has spent its life going to. With a reputable list of problems we can research them better and when we fix them he'll see a more direct link between the diagnosis and the treatment plan. Then again perhaps the only way to learn is to replace the o2 sensor on a system with an exhaust leak.
Back to where you are- I've been able to access the downpipe bolts from the top by removing the heat shield. Once the downpipe bolts are cracked a ratcheting wrench helps a lot as well. It'll. On my car I found that the PO had a very cheap ebay downpipe+cat unit fitted which has an improper turbo flange. It doesn't bolt down straight and won't sit flush on the turbo, using a thick dount-lile gasket instead of the thin eom gasket. I'm suspecting that this is the root of my p0420 and not my rear 02 sensor or even the cat efficiency itself.
Anyway, worth checking if that cat/downpipe is OEM and I'd suggest trying to get a look at that first one from the top. Perhaps you know from your v70s that removing the angle gear is a very big job. I suggest reading Richard99's write up on it for his v50. I managed to do it without removing the oil cooler but even still it's a long and frustrating job.
(1) Procedure for removing angle gear on a 2007 Volvo V50, AWD, M66 https://share.google/zuHAuYa9vx4MoQ9zD
Thanks for that useful info on the access. It is an aftermarket downpipe from the turbo, but he things the issue is the bolt holes or studs are stripping out so not necessarily the down pipe but poor connections. I'll let him know about this info as it will help moving forward.
As to your question on helping your brother. I mentor a few young guys to help fixing their cars. I do let them know that sometimes you have to ask the experts for help, but with all the basics I let them get stuck in with my tools and hoist and I help/supervise when needed or show them where there is an easier why you tackle an issue. All of them have shown an ability to learn quickly and a huge confidence in doing their own wrenching. Diagnostics is not always easy but they are learning but it takes time. I enjoy helping them and my time now I am retired is free. I do tell them also they don't have to wrench on the cars themselves all the time, but to at least learn how the car works so they can understand the pros and know if they are being ripped off.
Good Luck!
smacknab
Post by smacknab »
Thanks Neil, I suppose I'm in a similar boat offering my shop (no lift, unfortunately), tools and help for him to dive into what he might want to fix on the car. I enjoy it and hope it'll help him build the confidence. Plus it's nice brother time.
Good luck with the turbo studs!
Yes, not really looking forward to that. I may call in the pro, my buddy who is a professional mechanic and worked for Volvo for 15 years. He also owns 2 P1's and a P3 S60 all of which are similar but they are FWD. V50 is AWD so access to the turbo is blocked from below by the angle gear.
I don't mind tackling the studs once it is all out, but removal and re-install is better left to those younger guys when possible!
I an a retired Mach Eng, but worked for many years in Scotland as a production process engineer, production manager, safety engineer and ran and built factories. What I enjoyed most was training and mentoring techs and junior engineers.
Went back to the junkyards, well one of them. According to the PnP description they had just got in a 2009 C30 T5. My mechanic buddy was heading out of town so asked if I could go check it out and see if the rear bumper was good. There were a couple of parts I might be interested for my stash, and there was also a P2 S60 that may have a set of electric folding mirrors.
Get there, and yet again the car was mis-represented. It was a 2.4i NA, so rear bumper (which I told my buddy is different to a T5 2010- he still thinks he can make it work. There are currently no reasonably priced rear bumper covers for sale expect one which they want $500 CDN for at it is the wrong color. By the time it is painted you could have bought a new one ready painted. Only issue there is Volvo says they are not available, and even aftermarket panels are listing as NLA or out of stock. I did find one that want $2000 + for an aftermarket one painted in color!!
Anyway, the parts I was looking for were not there as they are only on a T5 not an NA. I wanted the throttle body and the MAF as I had one of each but both went to a friends T5 nightmare to fix it.
The S60 was a bust also, so I had a closer look at the C30 as my buddy is looking for rear lights as his are cracked. One was similarly cracked but the RH one was good so I pulled it. While I had the tailgate open I saw another unicorn! My buddy has been looking for a hard cover privacy cover/load cover for a C30 for 2 years, and so have I. I found one in an un-listed C30 2 weeks ago finally. Well I was amazed that here was another one!! I'm sure my buddy will want it as he has 2 x C30 T5's and neither had covers. This one is slightly broken as one of the dangling 'tails' on one side has snapped but is still there. I have a plan to fix that.
Then I was about to leave and suddenly realized there were a pair of roof rack rails on the car. I was thinking they would be a bust as they looked like you needed a key to remove them. A closer look helped me realize you just needed a large flat blade screw driver to turn the plastic lock 90 degrees. So those also came home with me. So not a total bust!!
My buddy (former Volvo tech) and I completed a 60k mile (96kkm) big service on our friends 2012 C30 T5. Car has just passed 190k miles (300kkm) and last big service was done at 202kkm. So it was overdue.
We had already done the trans flush when the owner broke the trans cooler line running over something last winter so we could skip that.
She had taken the car to a local repair shop near where she lived and was given a list of recommend repairs which included a fuel filter. I ended up ordering one with the other parts needed from Rock Auto where they listed one for it. Turns out there is no filter as such, only in the fuel tank as part of the pump!
We checked the brakes (my buddy had turned them at the time we fixed the trans line) as the repair shop said the rear pads needed done. Again bought the parts but they are no where near needing done. Probably got another 20k miles or more on them. Fronts have even more miles on them left. Both rotors will take a 2nd set of pads from a wear point of view. The owner does mainly highway driving so the brakes don't see a lot of use.
Brakes flushed, engine air filter, and the grubbiest cabin filter I have seen in a long time was also swapped. New plugs as well.
Car runs really well and we checked it all over. Needs new wiper blades (gone hard), ideally a windshield (multiple cracks), and finally a pair of tires. We also have to monitor one front shock that is getting sweaty.
These C30's are really starting to grow on me as a fun little car, especially in T5 version.
Well it is a sad day. My friend has moved on his 06 V50 to a new young owner. I think he got a fair price for it but it needed a lot of work including a steering rack and a windshield. He works long hours and no longer had time to fix the issues. I still have at least one more C30 T5 to come my way at some point that needs a full interior restoration follow multiple water leaks.
smacknab
Post by smacknab »
Did a full suspension and wheel bearing overhaul a few weeks back and have been tweaking it since. Cleaned up the brake slide pins and metal to metal surfaces as well as I'm tracking down little bit of shake while applying the brakes. Today I finally replaced the passenger axle carrier bearing bracket since it was grooved when the old axle bearing exploded.
I've got an upgraded downpipe and upstream O2 sensor to install but the car is feeling amazing. Such a fun mix of everything. The other day I transported a whole bedframe and today my friends and I were hitting redline and pushing the new the suspension.
