Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
When working on the turbo or CBV, I just put a moving pad over the engine, and lay down with both hands free. But then I am a spry, flexible septuagenarian :)
Junkyard trip today yielded some goodies: A C70 sub-frame brace,an ashtray, and a mostly intact cup holder.
Brace cost a whopping $13 !! :D
1999 V70 GLT
Has thanked: 2199 times
Been thanked: 1852 times
Can you still get the 'rooster combs' for the drink holders to replace the wore out originals? I wonder if one had a good original if someone could find a similar material to the rooster combs and one could make your own replacements.
I then found this on EBay for a supposedly upgraded cup holder and at a reasonable price:
https://www.ebay.ca/itm/360498538028
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Bought new battery.. engine block starts quicker :wink:
I had charge old battery today when going to work and when going away from work so it was enough to me :mrgreen:
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Managed to spring a leak, a hole on the thermostat cover, near where the upper radiator hose connects.
I'm planning to do a temporary fix with JB well and stanless steel zip ties to tide me over until I can source a replacement, but following the "might as well" rabbit hole past the radiator hoses and to the thermostat housing gasket that has signes of a slow leak. The question now is:
Can the intake manifold gasket be reused?
From what I understand, the thermostat housing cannot be replaced without removing the intake manifold. The one on there now is 2 years old, replaced when I did the PCV
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Couldnt find a coolant leak, but I found the missing coolant: in the oil :evil:
Compressions seems okay, but two spark plugs have the porcelain part looking very clean... Leakdown test tomorrow, hopefully that'll help me decide if it's the head or the radiator (which funnily enough, might be the more expensive of the two options :lol: )
RedBrickCollector wrote: 19 Mar 2026, 11:58 Managed to spring a leak, a hole on the thermostat cover, near where the upper radiator hose connects.
Bit of a roll of the dice, I've reused them but they can get brittle. If you can get your hands on a spare gasket, I would
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
I got into an accident about 1 p.m. today. I rear-ended an F-150. The elderly couple were completely unscathed. They were both fine and very kind. They had merged into the right lane while going slower than the right lane traffic. I was getting closer to them and thought they were prepping to slow more for the right turn before the bridge. But he suddenly braked hard and this dummy hadn't left enough room for such a thing. I had more response time than I thought I did (after watching my dash cam).
Someone needs to call the law office of APS (adult protective services) & APS (Auto protective services) (APS & APS). I'm a menace.
So I spent some time tonight doing some basic fixes.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1609 times
Been thanked: 4065 times
Not too bad, Antler Man.
I’m not back in 🇺🇸 until next week
The 1998 Riverside blue v70 has not sold so that’s still in play
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
scot850 wrote: 18 Mar 2026, 23:52 Can you still get the 'rooster combs' for the drink holders to replace the wore out originals? I wonder if one had a good original if someone could find a similar material to the rooster combs and one could make your own replacements.
My cup holder had the 'rooster combs' removed many years ago. It stills works as effective cup holder if the cup is not large.
I think you could find some 1/8 inch rubber sheet and maybe cut out 'rooster comb' replacements. Not sure if the thickness would work.
Sveedy
Post by Sveedy »
Cleaned and straightened the brace. After paint, I'm planning on putting it up till I can do the sub-frame bushings and the two hydraulic engine mounts on the V70. No need to buy the TTY bolts twice.
1999 V70 GLT
CIK7
Post by CIK7 »
abscate wrote: 20 Mar 2026, 04:22 Not too bad, Antler Man.
Is that Riverside CT or Riverside New Jersey? Who is selling this 98 v70 and what's the contact info? PM perhaps?
