Don't know yet.erikv11 wrote: 14 Apr 2026, 20:03 Hmmm, yeah, what's the compression in the four cylinders with good valves?
Lost compression on 4th cylinder
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
You can get the stem seal kit ftom Skandix ( Volvo only) as well as new valves. Reworked head under $1000 with your labour
Another 300k KM!
Another 300k KM!
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
I would also encourage you to try and remedy the original engine with new valve stem seals and valves. Likely just need to remove the head, not the whole engine.
I recently addressed oil burning in my 1990 Ford with the V6 Cologne engine by fitting new valve stem seals for $20. 4 of the old ones had just popped loose so were not doing anything.
- misha
I'm still thinking what to do.
I never opened any engine in my life.
Don't know exactly what to check and what to look for.
I can open the engine and remove the head but that would be all.
Stem seals could be the culprit,but the engine have moderate blowby from oil dipstick tube when running...piston rings,cyl walls,bearings also would need a check...since the engine would be opened anyway.
Piston rings can be easily replaced by dropping the oil pan and pulling the pistons from the top.
We'll see.
We'll see.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I agree with erikv11 - check the compression in the other cylinders.
I also had never taken apart an engine till I did the head on my V70. I found it to be surprisingly easy and enjoyable. But I had no time frame in which to get the job completed, so no pressure. Lapping the valves, cleaning everything up, installing new seals using a homemade spring compressor - all of it was very easy and rewarding. But again I was in no rush.
If you do need cylinder work, then obviously that's another ball game. When my 850 needed cylinder work, I just pulled the engine and took it into a shop, and had them do the pistons and rings after machining.
1999 V70 GLT
1999 V70 GLT
Your shop labour rates will be 1/4 of ours in Serbia - and the shop will have expertise, too.
I just did my first head job and loved it so much I did it twice!
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
100 to 125 mph on an engine with 450,000km on it? There's some stress test right there.
Maybe it's all in the head as abscate suggested. That's likely the cheapest option.
- misha
Engine never had a hiccup before this happened...well maintained also...but age and high mileage did the inevitable.
Purred like a kitten and no strange sounds from the engine of any kind.
Pulled and ran just like from the 1st day i bought it back in 2000.
Just burned 1l of oil/per 1000km and not a single leak from the engine.
Oil burning was like that for last 15 years.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 987 times
- Been thanked: 1075 times
Boroscope inspection of the cylinders might be good idea before teardown. There are good boroscopes available that connect to your smart phone. If the cross hatch on the cylinders are bad, then maybe no teardown.
- misha
abscate wrote: 16 Apr 2026, 08:26 ...I just did my first head job and loved it so much I did it twice!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
