xc90 2.9 2005 fuite huile entre boite auto et transfert
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
weyert
Year and Model: 2005 xc90 2.9 t6
Post by weyert »
no i have no problems with the anglegear it drips red ATF oil so its the joint of the gearbox
ggleavitt
Post by ggleavitt »
I might read the entire thread and the subposts. One example-
NO: 43-50
DATE: 05-10-2006
MODEL: XC90 T6
SUBJECT: XC90 T6 Chain Gear Leakage and Re-Sealing
DESCRIPTION:
XC90 T6 cars use a Chain Gear to transfer torque from the transmission to the angle gear. Oil leakage from the chain gear can be resolved by replacing seals and gaskets. The chain gear itself does not normally need to be replaced.
The majority of chain gear leaks are caused because the car has been disassembled for some other reason. The two chain gear seals which come into contact with the right front axle are easily damaged when the axle is removed and installed. The snap ring on the end of the axle can knock the spring off the seal and/or damage the seal lip. Whenever the axle is removed or installed for any reason (for example, when the transmission is being replaced) these two seals should be checked carefully and replaced if necessary. When installing the axle, insert it as straight as possible and be careful not to damage the two seals it passes through (8636015 &(NNN) NNN-NNNN.
Expert: FIXITMAN
Pos. Feedback: 93.9 %
Accepts: 261
Answered: 5/16/2008
TECHNICIAN/SERVICE ADVISOR
ASE MASTER CERTIFICATION, CALIFORNIA EPA A/C/IMACA, AA DEGREE AUTOMOTIVE/DIESEL
T6 Chain Drive View.JPG (28.09 KiB) Viewed 1650 times
edit- add photo, fix typos
weyert
Post by weyert »
its the seal 9445681 thats leaking,
ggleavitt
Post by ggleavitt »
Sorry for you. Thanks for the reply.
weyert
Post by weyert »
thank you
