MVS Readers,
This will be a short refresh and most of the content will apply to any P3 chassis.
My P3 chassis LR2 was manufactured in MAY 2007 which means that it has entered its 20 year on this planet.
My daughter has the LR2 most days but I got it for a few weeks to do the refresh.
All I had to do was let her borrow my 8 year old MERCEDES CABRIOLET.
Here is the as received condition
The first step is to clean up the vehicle so that I can see what I am working with.
Here is the post cleaning picture
I have a long list of things that I want to do watch this thread for more information
Thanks
Paul
The 20 year refresh on a P3 LR2 3.2 Topic is solved
- Has thanked: 2197 times
- Been thanked: 1850 times
For a 20 year old LR2, that is in amazing condition. The fact it is still running is a testament to care, as no Land Rover is expected to be running that old other then the old Series 2/3.
At least you have a good base to work on, so I wish you good luck on the renos!
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Scott,
The picture is the best angle.
I will likely do some paint work but that information will be in a future post
CREDIT to the VOLVO 3.2 for the longevity.
The LR2 is basically a S80 3.2 AWD under the bodywork.
I will post more as I move forward with the refresh.
Thanks
Paul
Thanks
Paul
- pgill
MVS Readers,
I checked the air conditioning today.
Top tip: if you are buying a P3 measure the AC vent temperature to confirm that the AC compressor is working properly.
For reference on my former S80 (my niece has it now) the vent temperature is very close to what I measured today.
Here is the link to what I measured on the S80
viewtopic.php?t=87687&start=110
Fun fact: Land Rover decided to use a single cooling fan for the radiator but the S80 dual fan is a drop in replacement. And I upgraded to it a while back.
Volvo upgrade #1 - dual cooling fan for a S80 fits perfectly
Take care
Paul
Take care
Paul
- Been thanked: 4064 times
Almost a 50F delta drop ! Awesome !
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
So about 50 degree is good for a modern AC? I remember that a 78 Ford I was in you could barely hold your hand in front of the AC vent because the exit temperature was around 35 F.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- pgill
The AC refrigerant level is set so that you get excellent cooling without the risk of building up ICE.
If the amount of refrigerant in the system is too low then the pressure on the low side will drop and you can get a lower temperature. But you take on the risk that the evaporator will become a block of ICE and then the cooling won’t get to you.
Hopefully this makes sense.
Or if you prefer the simple explanation then: it’s a refrigerator not a freezer.
Thanks for the input
Take care
Paul
Take care
Paul
- pgill
MVS readers,
I removed the air filter housing today to check for oil leaks at the Vacuum pump.
No leaks……one less thing to fix
Here is the close up of the vacuum pump
The engine is weeping oil out of its seals but it is not leaking.
Take care
Paul
PS even though the belt looks like it’s new I will replace it and the tensioner and the overdrive pulley because the overdrive pulley is seized solid. But that will be in a future post.
EDIT here is the old vs new air filter
Note the Volvo filter has a foam pad attached to the paper which makes the comparison slightly harder. If you do this test with your new Volvo filter you will get less light because of the foam.
Take care
Paul
- pgill
Getting ready to change the Spark Plugs
Here is what I do now that I have owned more than one 3.2
1. Carefully disconnect the connection at the coil and then mark the connector on the side that is visible when reinstalling.
2. Also disconnect the capacitor and the variable valve lift solenoids
3. I don’t disconnect the two ground wires because the wiring can be moved out of the way without disconnecting (but I do inspect the ground wires)
Take care
Paul
PS Here is a bonus picture for something that I found.
Take care
Paul
- pgill
I replaced the spark plugs today
From FCP EURO
“ This is a set of 6 OE Denso IKH20TT spark plugs made in the same factory as Genuine Volvo 31286359”
I did use 4 genuine VOLVO plugs and two IKH20TT plugs because that is what I had on the shelf
31286359 is the part number from Volvo later in the life of the 3.2. this is the Denso Iridium TT spark plug. I recommend getting the part directly from Volvo if the price is close to what the Denso plugs cost. The reason being that there are a lot of fake parts for sale.
I like to apply dielectric grease to the insulation as shown
Here are the old plugs and they look very consistent
After removing the coil and spark plug from cylinder number one you should take a look down the tube. As you can see from this picture the tube is extremely clean and it shows no signs of oil leaking.
One other thing to notice in the picture is FoMoCo on the aluminum casting. It a Volvo design Engine installed in a Land Rover but the engine was built in a FORD factory over in the UK
Some links with more information about spark plugs
https://www.freel2.com/forum/topic35121 ... ht=Ikh20tt
viewtopic.php?t=101753
From FCP EURO
- 2774 Views
Last post by TheMrFailz
- 2043 Views
Last post by oragex
- 1042 Views
Last post by 850forum
- 7532 Views
- 14 Replies
- 3004 Views
Last post by jcdillin
