Sveedy wrote: 24 Jul 2026, 12:20 Hopefully you saved the other 4 bolts that are also longer, but they are not TTY, so easier to find.
The brace came with the bolts. Only it’s the wrong ones.
I’m missing two small long bolts.
The big long bolt was he wrong bolt as well. My original bolt hat I pulled out is already the longer bolt already.
Yellow marked is what I picked up with the brace. Top bolt is from my car. When I pull the smaller long bolts from the driver side, it was coated in some oil type fluid. Anyone know what is above those two bolt mounts? I’m going to look for the two smaller long bolts, but for now I lightly tightened the shorter bolts with loctite.
