1992 850 GLT crank no start, no spark
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Another suggestion that may help others see and diagnose your no-spark condition: take and post a photograph of the engine bay and especially the area around the ignition coil.
zero2218
- Year and Model: 1992 850
Replaced the ignition coil and camshaft sensor today. Still no start. Cannot replace the distributor rotor due to a damaged bolt head but it is spinning along with the crankshaft.
I have a doubt about my firing order and if it is correct or not. In the specifications document the firing order is 1-2-4-5-3 (clockwise) on the distributor. However guides like this one says it is 1-3-5-4-2 (clockwise) https://www.matthewsvolvosite.com/volvo ... ing-order/
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
If I recall correctly, two adjacent cylinders firing in order only occurs once on these engines.
1-3-5-4-2
1-3-5-4-2
1999 V70 GLT
1999 V70 GLT
- jreed
If your rotor bolt won't come loose, you may be able to get it to come free using locking pliers, as shown below: viewtopic.php?t=93539zero2218 wrote: 17 Aug 2026, 07:30 Replaced the ignition coil and camshaft sensor today. Still no start. Cannot replace the distributor rotor due to a damaged bolt head but it is spinning along with the crankshaft.
zero2218
Did some testing today. Spark at the coil but still none at the plugs. Tested several cylinders to be sure. The only ignition part I didn't replace yet is the distributor cap. I wonder how replacing it would fix the issue considering its looking good and clean.
- RickHaleParker
- Been thanked: 979 times
Look for tiny cracks in the Cap and Rotor. Flip the Rotor over and look at the bottom side.zero2218 wrote: 26 Aug 2026, 05:33 The only ignition part I didn't replace yet is the distributor cap. I wonder how replacing it would fix the issue considering its looking good and clean.
Still recall being stranded overnight because the Rotor was cracked. All the power was going straight to ground through the shaft.
Active
Past
Past
- jreed
When you are testing for spark at the coil and at the plugs, are you using the same grounding metal for the test?
Asking because it could be a poor/high resistance ground on the engine block is preventing the spark at the plugs.
zero2218
No visible cracks in the cap. Looks in good shape. The rotor is replaced now.Look for tiny cracks in the Cap and Rotor. Flip the Rotor over and look at the bottom side.
I believe a cap replacement would end the doubt about it.
- 256 Views
Last post by volvolugnut
- 9 Replies
- 2523 Views
- 29 Replies
- 7166 Views
Last post by Chuck W
- 3502 Views
Last post by Empathron
- 1128 Views
Last post by nmotzing
