Vida CEM swapping
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Did two CEM-L . First three bytes went straight to the top on the first pass ( range 100, samples 10 ).
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 21 Sep 2026, 13:32 Did two CEM-L . First three bytes went straight to the top on the first pass ( range 100, samples 10 ).
Nice!
vtl
Post by vtl »
Also
https://github.com/vtl/volvo-cem-cracker/issues/43
Not sure if he was able to crack it successfully after disabling the speculation.
RickHaleParker
vtl wrote: 22 Sep 2026, 14:17 Not sure if he was able to crack it successfully after disabling the speculation.
He has not said if he was going to try disabling the speculation.
I been looking for a way to delay arming my RX hardware capture until the TX CAN frame if finished. But I would rather keep it independent of the M7. 300us maybe longer then a CAN frame but is it always shorter then TX CAN frame + latency ?
Active
Past
RickHaleParker
Screenshot from P80 Diag.png (52.92 KiB) Viewed 268 times
Open source diagnostic for K-Line volvos. P80, X40, 900 & S/V90.
Supports interfaces KKL/FTGI, ELM357/OBDLink and J2534 including DiCE.
(J3534 supported in windows version only)
Linux Debian and Windows versions. Need somebody to compile a MacOS installer.
GitHub https://github.com/RickHaleParker/P80-D ... /tree/main
End users can down load the installers here:
Active
Past
