Any help would be greatly aprreciated. Thank you, Christopher
'92 740 ? water pump going bad? Topic is solved
christopher t.
arete
Make sure it is the pump and not some gasket between the pump and another part allowing the coolant to leak.
On the B230 engines there is a rubber grommet-like gasket between the water pump and engine block. These deteriorate over time and will start leaking. It's a big pain because the water pump then has to be removed to replace a $0.50 part!
There is a "weep hole" in the water pump casing. If there is antifreeze leaking from the weep hole, then the water pump is probably failing.
Those are the two things to check, the rubber gasket and the weep hole.
The last time I replaced the water pump, about four years ago, I used a HEPU (German make) and it's been fine. Also it cost about a third of what the Volvo dealer wanted.
Tom Finley
'97 854 T-5
'85 245 GL
'97 854 T-5
'85 245 GL
Kreg
I have a 93 240 sedan. I think it uses the same engine as yours. I have 90kmiles and I had leaking anitfreeze.
The solution was to replace the gasket on the water pump. The symptom was the antifreeze was blowing on the exhaust and smelled like burning plastic.
Since the pump costs about $65, you may want to replace it at the same time. Note that I have heard that Volvo waterpumps last a very long time.
Kreg
Kreg
