Any one out there done it?
Thanks
You'll need voltage stabilizers. Your HIDs draw 35W, while halogens draw 55W. What I'd really recommend is installing an MTec HID kit for the Volvo S60, their ballasts for the P2 cars doesn't trigger the bulb failure circuit of the CEM, which causes your DIM error message.esconet wrote:The Kit works great (HID is the way to go) but it causes the driver information center to constantly flash Low Beam Failure, even though its still working. I suspect it is due to the change in wattage/Amperage...Is there any way to disable or reset parameters for this Drivers Info center?
