My passenger headlight was broken. I bought new glass only from FCP. I followed the directions found elsewhere on this site to remove the bumper and remove the assembly. So I got it off and removed all the old broken glass. There is a sealant of some sort holding in the old glass. Previous experience with glass replacements I've seen rubber gaskets - one did not come with the new glass nor did new sealant. The dealer says there is no gasket available (they didnt have the glass either - they said to replace the whole unit for $500).
So my question - Can I use some silcone sealant to set the glass? Should I press the new light into the somewhat pliable old sealant? Something else all together?
Thanks for any advice!
2002 s60 2.4T - broken headlight
Volvo s60 24t
- Year and Model:
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
The dealer is correct, there is no gasket. It's made with bonding adhesive. The Volvo P/N is 1161767 (superseded from 1161377). I'd assume it's a higher-temp RTV, given that the glass needs primer (Volvo 1161515). I've attached instructions.Volvo s60 24t wrote:My passenger headlight was broken. I bought new glass only from FCP. I followed the directions found elsewhere on this site to remove the bumper and remove the assembly. So I got it off and removed all the old broken glass. There is a sealant of some sort holding in the old glass. Previous experience with glass replacements I've seen rubber gaskets - one did not come with the new glass nor did new sealant. The dealer says there is no gasket available (they didnt have the glass either - they said to replace the whole unit for $500).
Replace headlamp and sealant - S60.pdf- (580.02 KiB) Downloaded 242 times
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
1999 S70 GLT
