P0194 engine code
vromanis
Year and Model:
P0194 engine code
Post by vromanis »
Hi,
I have Volvo V70, 2003. The "Check Engine" icon popped up and diagnostic showed the following: P0194 Fuel Rail Pressure Sensor Circuit Intermittent.
I close fuel tank cap tight after refueling and icon goes away. Then wnen fuel tank is half empty the icon comes back.
Does anyone know what to do with it?
Thank you.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Sounds like a fuel pressure regulator that is going bad or you have a bad line inside of your fuel pump. someone else posted with something similar (although on an earlier car) tonight regarding the same symptoms as yours: https://www.matthewsvolvosite.com/forums ... =1&t=18232
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Exactly what is says, the fuel rail sensor, they go bad
Usually the car runs like crap.
You really need to get it to Volvo, their diagnostic is more pin-pointed
mike48
Year and Model: 2003 v70
Post by mike48 »
Please check the recall/ defects for 2003 v70 volvo. i believe that was a recall item
Mike48
vromanis wrote:Hi,
Thank you.
sony2000
Year and Model:
Post by sony2000 »
Yes it is one of the latest recalls. 04 V70.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
