If this is the transmission is it worth fixing?
Also did not pass emissions testing. I had the fuel filter and few other items changed. The spark plugs were not pushed in all the way. Runs better now, but haven't retested yet.
As for the emissions test, it's good measure (if you don't do this already) to drive the car down the expressway for 15 or so minutes before going for your emissions test. Also, how new are your sparkplugs and airfilter? You may also have some luck cleaning the PCV system, which is a good idea to do anywayA 30 minute run; back to a level surface; apply parking brake; engage P and, with the engine idling move the selector lever through all gears pausing for 4-5 seconds in each position. Back to P and let engine idle for about 2 minutes, remove dipstick, wipe on a lint free cloth, replace dipstick then withdraw it and check the reading.
