I stopped browsing this forum and joined, I don't know, a week ago 'cause I finially bought an 850 wagon. So I had a laundry list of things I wanted to share/ask about and I started with the outer trim, how to clean, keep it up(its a white wagon with gray trim).....well I got no love on that inquirey, BUT NOW I HAVE A SERIOUS PROBLEM AND IT'S NOT FUNNY. The glove box door locked it'self last nite and won't open. The ignition key fits but won't turn. I like to drive this car as it was meant to drive which kinda leaves me hanging out far enough that I can get noticed.........if you "catch my drift". The registration for the car is in that glovebox and should the situation arise where I may need to show it to somebody, I don't want to have to do damage. So please, if anyone has had any expierence with this problem give us a post back
thanks much(i hope)
Leev
OK, this time I'm serious...
leevining1
- Year and Model: 850 sport wagon, '96
Welcome.
Here is what you probably need to do to get your glove box open.
https://www.matthewsvolvosite.com/forums ... php?t=8205
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
leevining1
mcp: well, thanks for that, I am hoping for a non-surgical solution, but if not it's good to have that. you sure have a load of manual transmisson cars, mine is a '96 sport wagon, the only way it could get sportier would be a 5-speed. I would guess your mileage is pretty good and the driving even better. Did you order them new to get the manuals?
- Has thanked: 2664 times
- Been thanked: 1256 times
There are five glove box fixes in the Repair Database.
leevining1
matthew..I'm just going to have to learn to navigate around here.....thanks alot
leev
leev
Ordered the '98 S70 new. Found the '96 850 on a Volvo dealer's lot in May '98 with 25k miles on it. Just found the '97 850 wagon a few weeks ago on Craigslist.
All of them get about 26-27 mpg around town and 30-31 mpg on highway trips. I wish Volvo had sold some 850 turbos with manuals in the US, but apparently they didn't. You could order an S70 turbo with a manual, but not many were sold.
If your glove box latch has broken, about the only way to get in is to saw through the "loop" catch at the top. It is held on by two screws so can be replaced easily. Or do you think it is simply locked and you don't have the correct key? Either way you probably are looking at sawing through the loop. In the various postings about this problem, one suggestion was to use two putty knives (or two pieces of thin metal) to protect the vinyl dash and glove box door and slide the hacksaw blade between them. Taping part of the hacksaw blade worked for me.
JRL
- Year and Model: Several
- Been thanked: 16 times
As for your trim.
When it gets a bit warmer, take a Sat afternoon, carefully mask all the trim off, clean it with a prep solvent, lightly scuff with a Scotch pad and paint them. You will never have to worry (for many years).
Use spray can of gray/black bumper paint, available everywhere
leevining1
Well fellas thanks a bunch......actually I stopped by my favorite key kiosk and the guy had some thin flexible metal thingies he invented when he was pressed into volvo glovebox service years ago and he sprang the door, i have taped it and will proly go by volvo dealer or faxsimily and get a new latch. Thanks for the tip on the trim. I'll test a spot first, I can see where preping the surface is most important. So now the red brake lite starts coming on and fluid is low....fill up, two days later, lite is on. now I find the line underside the main resivour is wet, looks like I take it off perhaps a new tank or line or both
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
May be a bad master cylinder. Don't waste your money on a new one- they are cheap at a junk yard if that's it. Check the metal pipe connectors at the bottom- sometimes these get loose and leak as well.
- Year and Model: Many Volvos
- Been thanked: 76 times
Is there any way you can get a picture of this contraption?actually I stopped by my favorite key kiosk and the guy had some thin flexible metal thingies he invented when he was pressed into volvo glovebox service years ago and he sprang the door
After I sawed through my first one and saw how it worked I hypothesized that the latch could be popped from behind without sawing through the hoop. I then got busy on other stuff and never pursued the solution.
- 68 Replies
- 10467 Views
Last post by 1ezliving4ume
- 1475 Views
Last post by 93Regina
