Heated Seat Relay/Control Module
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
dlevek
Year and Model:
Post by dlevek »
Does anyont know where I can get a heated seat relay/control module - Volvo Part No. 3523890, Valeo (manufacturer) Part No. 02 664, for a 1997 Volvo 960? So far, the Volvo dealership seems to be the only place it is available at a rather hefty cost - much, much more than it cost to produce the item. Thanks!
Gilles from Richmond Hill
Post by Gilles from Richmond Hill »
I have a 1997 V90 with a passenger seat that won't heat. Where is the heated seat control relay located? I'd like to check it, having eliminated the fuse and switch as the problem. Thanks [email protected]
I just found it under the seat of course. I took it apart and know that it clicks on once the button is pushed. If you listen carefully you'll hear it click on. Before buying a replacement, you might want to switch it with the other seat relay to make sure it's the problem. If it is defective you can pop the relay open and check out the solder joints and components.
Good luck.
theseafox
Year and Model:
Post by theseafox »
I have these ans hundreds of others for sale.
I ship worldwide.
TheSeaFox On E-bay.
or write to: [email protected]
leo
