95' 850 GLT Wagon (non-turbo)
1. Central Locking: Front 4 door locks work fine. Problem is with the 5th door lock. When using the key in the front doors the 5th door lock does not operate. When using the key with the 5th door all the doors lock and unlock just the way they are supposed to. I need advice on what to look for as a problem, dealer wants to change the lock in the 5th door and charge about $250. I am very handy man and so need advice.
2. Key Fob: It unlocks all the doors but does not lock them. Battery is new and distance does not matter. Doors will not lock irrespective of the distance.
Advice on both the points above will help. What should I try for point 2 the key fob.
Central Locking & Key Fob
- dosbricks
- Been thanked: 2 times
If the 5th door lock motor (solenoid) were bad it seems that the key in the 5th door and the remote unlock wouldn't work either.
When one of our remotes started to go bad it quit opening first and then quit locking the car. I think this is because the problem is with the button switches. They get some green corrosion around them and although you can take the circuit board out of the case, the switches don't seem servicable. I tried cleaning, new battery, reprograming, nothing worked.
Sounds like if you were down to only one remote you may have to get another one. Yeah, I know, all this isn't much help.
- Has thanked: 2652 times
- Been thanked: 1245 times
Sounds to me like the 5th lock is sticky or the motor is toast.
- 1707 Views
Last post by mike178wright
- 2904 Views
Last post by jtp
