98 S70 GLT Smokes when
bdnolan2
Year and Model: S70 GLT 1998
Post by bdnolan2 »
When Decelerating after passing some one the car blows blue smoke and a good bit, :evil: does not smoke any other time. was suggested to try replacing valve seals as this is cheaper and easier. any other ideas
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
This is very strange...if the seals are bad, you would get the blue smoke on acceleration too. I'm thinking some kind of vacuum leak that is messing up your air to gas ration causing you to burn rich.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
How big is oil consumption?Is it much?
For example:
How much oil you need to add to your engine after 600miles?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Craigd2599
Year and Model: 2007 S40.
Has thanked: 3 times
Post by Craigd2599 »
Rings or seals. But I've never seen that kind of oil from a vavle seal. Valve seals will load up the cylinders at idle but not usually blow by like that.
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
bdnolan2
Post by bdnolan2 »
2 weeks 800 mi. 1/2 to 3/4's of a quart, I thought about a vac. leak also also when sitting and rev the engine it does not blow smoke either. Just checked the oil as I wrote this. :shock:
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
bdnolan2
Post by bdnolan2 »
I just bought the car 2 weeks today paid 2700.00 for it!
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
Craigd2599
I don't own a turbo myself so MIJ may know more about this but it sounds like maybe the turbo? Those things are oil cooled and maybe it's passing oil into the wastegate somewhow? (If that's ridiculous, just ignore it)
Craig D
MadeInJapan
Could be the PCV...somehow, boost gets the blow-by oil into the system...but because of a clog, the vacuum doesn't work the other way- thus pooled oil when there is suppose to be a vacuum burns off...I would check that if it hasn't already been checked.
bdnolan2
Post by bdnolan2 »
will check the pvc Thank you! :D
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
misha
Post by misha »
If it's not PCV,then could be o-rings or valve seals.But with your oil consumption it's not a big deal YET.
Start with checking your PCV and TURBO(if it's bad it,could be reason of burning oil).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
