740 GLE Timing Belt
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
volvodude18
740 GLE Timing Belt
Post by volvodude18 »
:? I have a 88 740GLE and the timing belt just broke on it. I need to know if there is any damage done to the engine or if it will be fine just to replace the belt. Also when the belt broke the car was only at 2000rmp
Should it be alright???
email: [email protected]
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
If it's a 16 valve, it'll likely have damage because it's an 'interferance' engine -- the valves and pistons overlap.
If it's not 16 v, or you didn't hear anything when the belt broke, you're probably a-ok. :P
Also -> Amazon link
volvodude18
:( Well my 740 has a 2.3 which i believe is a 8v right??? I'm praying!!! but when the belt broke the car automatically stalled and i didn't hear anything clanging or banging in the engine....and like i said it wan't reved too high, so should it be fine??? I guess we'll find out anyway since it got towed to the shop today!! Thanks alot!
Volvord
Year and Model:
Post by Volvord »
Easy way to tell which engine you have. Do the spark plugs go into the right side of the head or are they in the top and middle of the head. I would say that there is a 90% probablity that your engine is the 8V which has the plugs entering the head on the right side (passengers side). The 16V twin cam positions the spark plugs in the top center of the combustion chamber, they are installed through the top and center of the valve covers.
As VolvoDude mentioned, the 8V will probably be OK, when the belt breaks the cam and distributor stop turning, which causes the engine to immediatly stop
Volvord 784VC
http://www.telusplanet.net/public/gilesij/Volvord/
