Sunroof stuck
mmelchor
Year and Model: 2003 S80
Sunroof stuck
Post by mmelchor »
I have a 2003 Volvo S80 and my sunroof is stuck in the ventilation position. Is there a wat to close it until I can get it fixed? There is zero motor noise..no sign of life for the sunroof. all the fuses look fine.
Help!
Manuel
VCA
Year and Model: 2008 S80 T6 AWD
Been thanked: 5 times
Post by VCA »
mmelchor wrote:I have a 2003 Volvo S80 and my sunroof is stuck in the ventilation position. Is there a wat to close it until I can get it fixed? There is zero motor noise..no sign of life for the sunroof. all the fuses look fine.
Help!
Manuel
Have you tried holding the switch in the 'down' position for 5 seconds? Also, try this: using a key, lock and unlock the doors 3 times. This resets the UEM and might bring the sunroof back to life.
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
mmelchor
Post by mmelchor »
I have tried all those things. Thanks for the tip but nothing seems to work. I was hoping there was a way to manually close it. I hope it just a bad switch and I don't have to replace the motor.
Manuel
