1993 850 Sunroof Stuck Completely Open
Paul-93-850
- Year and Model: 1993 850 non-turbo
My 1993 850 sunroof just got stuck completely open. The inner sliding shade is stuck open too. I hadn't used it in years and heard wind noise so I thought to open it and clean the rubber but then it got jammed open. Shouldn't the shade slide independently? Could it be holding the sunroof from moving? There are no sounds when I press the close switch and fuse 35 is OK.
1337
- Year and Model: '18 VW Golf 1.8T 5MT
This RobertDIY video is good for getting a sense of what's going on inside of the sunroof mechanism:
(sunroof info starts at 2:12 into the video)
I haven't had my sunroof apart before, but I hope this video helps a little bit. Good luck!
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
Paul-93-850
After lots of banging and pushing and pulling it started to move again and it closed tight. I'm going to tape something over the switch and never move it again if possible.
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
If it's on its own circuit, pull the fuse. There's nothing more tempting to some people than a switch marked 'do not touch'!
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
