89 740 GLE 16 Valve
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
stacie
89 740 GLE 16 Valve
Post by stacie »
the timing belt broke, we replaced it and it. Now it will not fire at all, with a couple of bent valves wouldn't it still start? and just run like crap? Or is there something else I should be looking for? Any input would be greatly appreciated.
Volvord
Year and Model:
Post by Volvord »
There are a few items that can cause a no start, the main ones being that the belt is not installed correctly (valve timing incorrect) or the distributor is off (ignition timing incorrect) . But realistically if the belt on your 16V broke you probably have more than a couple of belt valves, probable more like 16 in which case the engine will not start.
Sorry to be the bearer of bad news.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
