960 Timing Belt
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
arbop
Year and Model: 2004 V70
960 Timing Belt
Post by arbop »
If you have the timing belt on a 92 960 break, does it also bend the valves? What kind of damage should I expect? Thanks
Current: 2004 V70
Prev: 73 1800ES, 76 240DL, 79 245 manual, 78 242GT, 81 245 GLT, 87 745 Turbo, 97 850 T-5, 89 745 manual wagon, 1992 240, (this one saved my life!). 2004 V70 2.5T. Whew!
JDS60R
Been thanked: 3 times
Post by JDS60R »
It appears the motor is an interference motor so valve and piston damage is expected. Especially if at high rpm when it broke.
You can put a head/or valves and pistons in if damaged but remember to weigh the cost vs a good salvage motor and a reasonable charge to put it in.
I would rather spend $500 on a low mileage motor and $250 plus hoses,new timing belt/water pump (figure $1200) etc to put the motor in as compared to a $600-$1200 repair (24 valves at $50 each is $1200 in valve parts alone.)
Retired
