manual transmission--difficulty shifting
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mickeysvolvo
Year and Model: 1991 240DL
Post by mickeysvolvo »
New clutch and used gear box installed about a year ago. Recently it has been difficult to shift into first gear. Car has 157,000 miles.
It is a 1991 240 DL. Transmission people say it is a clutch problem; mechanic who installed clutch say it is a transmission problem.
Sage advice appreciated,
Mike Silver
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If the clutch is cable operated, as some 240s are, check the cable adjustment. There should be free play of approx 1/8" before the cable starts to pull the release lever.
If it is a hydraulic system try engaging 2nd gear and then 1st. If it engages easier then you may be starting with synchro problems. That technique helps the synchros to engage. It also works with the cable clutch.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
