Manual Transmission Sloppy Shifting Topic is solved
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
Hey everyone. On my 95 850 Non Turbo, my manual transmission is shifting sloppy. I changed out the rubber bushings with stainless steel bushings on the transmission, so it cant be those. Basically the horizontal motion is tight (ie left to right) but the vertical (forwards and backwards) is super loose and when its in gear it continues to move back and forth. I can post a video if desired. Its especially bad between 3 and 4. I'm not sure if its the cables or the shifter. I actually went ahead and tried to find new cables but it looks like no one makes them anymore.
What is the proper diagnosing procedure here? Take apart the center console and check the shifter next? I'm in the middle of working a double delivery shift so I wont be able to take anything apart until tonight.
Thanks for the help in advance.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I know this isn't very helpful, but my 94 T5M has the same issue. Getting into reverse might take 2 or three tries.
1996 855 R,
2010 V70 D5,
callahanoffroad
Clemens wrote: 07 Jul 2019, 01:43 I know this isn't very helpful, but my 94 T5M has the same issue. Getting into reverse might take 2 or three tries.
This does actually help. Means I'm not crazy. :lol:
I took a look at the engine side of the shift linkage and everything still looks good. The actual vertical shifter moves forward and backwards smoothly in the transmission. The transmission part swings like butter. So if there's an issue I'm betting it's in the shifter itself.
I'll report back as soon as I have info
callahanoffroad
Okay reporting back.
Turns out I'm a hypochondriac.
There was absolutely nothing wrong with my shifter. Like nothing at all.
Clemens
Post by Clemens »
That´s good news. I´m like that myself, btw. ...
1996 855 R,
2010 V70 D5,
callahanoffroad
Clemens wrote: 08 Jul 2019, 13:20 That´s good news. I´m like that myself, btw. ...
Hahaha. Well I forgot to add what the fix was. It was adding a Snabb short throw shifter to the car. Shifts are crisp and sporty. It has been two days of driving with it and it really does breathe new life into the old 850. Now I just need a boosted turbo engine to go along with this sporty shifting. :lol:
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
The factory shifter is garbage. The Snabb short shifter is, like, required. If I had an 850 with three wheels and four pistons, I'd probably order the short shifter first.
callahanoffroad
j-dawg wrote: 09 Jul 2019, 01:35 The factory shifter is garbage. The Snabb short shifter is, like, required. If I had an 850 with three wheels and four pistons, I'd probably order the short shifter first.
:lol:
You so succinctly captured my exact feelings.
