Hi,
I'm having problem with my engine running on a few seconds after I have turned off, It happens when the engine is hot & not so much when it's cold.
I have only had this car a few weeks & have put new Volvo plugs in, new air filter, new Rota & distributor cap as I had a misfire problem but this was fixed after fitting the Rotor & dis cap. Took it to my local dealer & they said it showed a fault code 2-2-2 which is the ait temp thing in the air filter box but this was a week ago before the engine started running after switching off.
Any advice as to what I do now would be very helpful
Thanks
850GLT 2.5 10v running after switching off
It sounds to me like pre-ignition to me.
What Fuel are you burning? I think Volvo recommends 92 octane. I run 89 octane in my 95 GLT NA 20v with no problems.
Also, a cause may be a
95' Volvo 850 GLT, Lots 'o' miles, 118k, Broke in just right.
90' Ford Ranger 4x4, Even more miles, 145k, Seat is broke in just right.
02' Ford F-250 Super Duty 4x4, 85k, Working on the first 100k
- dosbricks
- Been thanked: 2 times
Go to volvospeed.com and do a search on "italian tuneup".
Guest
Thanks guys,
Do you think the fault 1-2-2 could cause this problem if the air intake senser is faulty or not working ?.
What product that goes in the fuel do you use to rid the carbon ??
- Tsquared
- Year and Model: 11 C30
Part of my 5K service that I perform is to put 1/2 can of Seafoam in the gas tank (full - 87 octane as per Volvo manual). Then with the engine warm and running I remove the vacume hose in front of the trottle body and using another hose I let the car suck the remaining Seafoam into the the engine. Once all of the Seafoam is in, I shut it down for 30 minutes. I then start the engine and get it back to temp - there will be huge amouts of white smoke coming out of the exhaust until all of the Seafoam passes through the system. This will clean carbon out of your intake/head and clean you injectors with the trated gas in the tank.Anonymous wrote:What product that goes in the fuel do you use to rid the carbon ??
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
