850GLT 2.5 10v running after switching off
moomac4
Post by moomac4 »
Hi,
I'm having problem with my engine running on a few seconds after I have turned off, It happens when the engine is hot & not so much when it's cold.
I have only had this car a few weeks & have put new Volvo plugs in, new air filter, new Rota & distributor cap as I had a misfire problem but this was fixed after fitting the Rotor & dis cap. Took it to my local dealer & they said it showed a fault code 2-2-2 which is the ait temp thing in the air filter box but this was a week ago before the engine started running after switching off.
Any advice as to what I do now would be very helpful
Thanks
Guest
Post by Guest »
Sorry it should be Fault 1-2-2 (Air intake faulty or intermittent)
Da' Moose
Year and Model:
Post by Da' Moose »
It sounds to me like pre-ignition to me.
What Fuel are you burning? I think Volvo recommends 92 octane. I run 89 octane in my 95 GLT NA 20v with no problems.
Also, a cause may be a
95' Volvo 850 GLT, Lots 'o' miles, 118k, Broke in just right.
90' Ford Ranger 4x4, Even more miles, 145k, Seat is broke in just right.
02' Ford F-250 Super Duty 4x4, 85k, Working on the first 100k
dosbricks
Post by dosbricks »
Go to volvospeed.com and do a search on "italian tuneup".
Guest
Post by Guest »
Thanks guys,
Do you think the fault 1-2-2 could cause this problem if the air intake senser is faulty or not working ?.
What product that goes in the fuel do you use to rid the carbon ??
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Anonymous wrote:What product that goes in the fuel do you use to rid the carbon ??
Part of my 5K service that I perform is to put 1/2 can of Seafoam in the gas tank (full - 87 octane as per Volvo manual). Then with the engine warm and running I remove the vacume hose in front of the trottle body and using another hose I let the car suck the remaining Seafoam into the the engine. Once all of the Seafoam is in, I shut it down for 30 minutes. I then start the engine and get it back to temp - there will be huge amouts of white smoke coming out of the exhaust until all of the Seafoam passes through the system. This will clean carbon out of your intake/head and clean you injectors with the trated gas in the tank.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
