Can anyone help two small problem
bjo09
Year and Model: S80 2.9, 2003
Post by bjo09 »
we have a S80 2002, 2.9 , seen last week the lower part of the consel AC, Heat, tracking control stop working , We check all the fuses they are all OK
Second problem is code 045 on left side display window ones we try to reset.
Can anyone help out there
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Did you check the fuses in this fuse block?
vegasjetskier
Make sure you check these two fuses:
bjo09
Post by bjo09 »
Thank you I did check them and they were OK, but I will replace them today and will see what happen, I will also disconect the battery for a while.
BJO
bjo09
Post by bjo09 »
vegasjetskier wrote:Make sure you check these two fuses:
Just to let you know I did check and replace the above fuse and it still does not work I even disconet the battery for about 20 minutes, with the same result. Do you know if there is a seconds place ther would be second fuse .
BJO
vegasjetskier
No, I think that's it for fuses. I believe that there is a relay on the Climate Control Module. Maybe that went out. Can you list everything that doesn't work; seat motors, heaters, etc.?
bjo09
Post by bjo09 »
vegasjetskier wrote:No, I think that's it for fuses. I believe that there is a relay on the Climate Control Module. Maybe that went out. Can you list everything that doesn't work; seat motors, heaters, etc.?
The following thing are not working, All of the AC and Heat control the Key truck swicth, STS switch, rear and front deforest back haed rest switch there is no power at all to any of the above switch
vegasjetskier
bjo09 wrote: The following thing are not working, All of the AC and Heat control the Key truck swicth, STS switch, rear and front deforest back haed rest switch there is no power at all to any of the above switch
I think you might have a Central Electronic Module failure. You probably should take your car into a Volvo shop or dealer to have it diagnosed.
bjo09
Post by bjo09 »
Thank you I will take to vehicle in..
