850 turbo 1994 check engine light
shynepo419
Year and Model: 850 turbo, 1994
Post by shynepo419 »
i just got a diagnostic test on my 1994 850 turbo. And i got 9 codes. Damn!
system to lean, knock sensor 1, Maf/Vaf circuit(high input), ignition system misfire, cylinder five misfire, cylinder three misfire, random misfire, EGR flow insufficent and knock sensor 2... We have no volvo dealership where i live. Can someone give me and idea what i could be dealing with. Thanks alot.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Welcome to MVS,
If you can post the code numbers it will help us to help you solve your problems.
The codes from the OBD-1 socket (A-2) under your hood are the most helpful. Here is how to read them:
http://volvospeed.com/CheckEngine.php
shynepo419
i will try to get them. i took it to the advanced auto and got the descriptions, but i dont think they want to release to codes to you.
Post by Ozark Lee »
You don't need Advance Auto Parts, only your own finger to push the button and a pen and paper to write down the codes that it flashes back. See the link I posted.
shynepo419
Well i finally did it lol. i used the link Ozark lee gave me and these were the codes i got. (1-4-3), (1-2-1), (4-3-3), (2-4-1) and (2-3-1). like the link said i put the jumper in A2. So im hoping someone can really help me by telling me what these codes mean. Thanks alot. :D
shynepo419
can someone help me out please. Thanks again
Post by Ozark Lee »
1-2-1 = MAF sensor signal.
1-4-3 = Front knock sensor signal.
2-3-1 = Long term fuel trim - partial load.
2-4-1 = EGR flow malfunction.
4-3-3 = Rear knock sensor malfunction.
The MAF sensor code will lead to the fuel trim code. With the knock sensor codes thrown into the mix start by check the ground leads on the block.
The EGR flow code is due to the hole above the EGR valve on the intake manifold being plugged up with carbon deposits. You will need a new EGR valve gasket and a new intake manifold gasket to fix it. If you have not yet serviced the PCV this is a dandy time to do that as well since about 80% of the work involved in that job is removing the intake manifold.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I received the 1-4-3 code on my 850 and it ended up being a bad set of spark plugs. I had the expensive 15 dollar a plug ones but the car did not like them. When back to the OEM ones and she has been happy ever since.
shynepo419
Thanks alot Lee. What is the PCV and how do i go bout servicing that. If i need to change both the front and rear knock sensors how much do you think a job like that would cost? And in your opinion just from seeing theses codes do you think i would have to change them? Thanks again
shynepo419
FCPGroton wrote:I received the 1-4-3 code on my 850 and it ended up being a bad set of spark plugs. I had the expensive 15 dollar a plug ones but the car did not like them. When back to the OEM ones and she has been happy ever since.
Thanks i guess i would use the OEM ones to avoid making her unhappy.
