Electric Seats
rogoal16
Year and Model:
Electric Seats
Post by rogoal16 »
Help needed with my son's S-70 T-5 electrical seats. The back portion of the seat does not go up nor down. All other parts of the seat work fine except the back of the seat.
Guest
Post by Guest »
There is a drive cable in the back of the seat that needs to be replaced. The leather has to be removed from the seat back in order to access the cable.
Guest
Post by Guest »
There is a drive cable in the back of the seat that needs to be replaced. The leather has to be removed from the seat back in order to access the cable. It is also possible that the switch is bad. You will be able to tell by listening for the motor while operating the switch. If you don't hear the motor, you probably need a switch.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2662 times
Been thanked: 1256 times
Post by matthew1 »
Also -> Amazon link
Cossack
Year and Model: 2007 S60R
Post by Cossack »
Both seats in my '94 850 are stuck, but I can hear the motor on both sides. Is it still the cable in those cases, or would it be more likely to be a gearbox problem?Can you hear the motor if the cable needs replacement?
thanks for any advice!!!
2006 S60R MT
yeagermeister
Year and Model:
Post by yeagermeister »
Cossack wrote:Both seats in my '94 850 are stuck, but I can hear the motor on both sides. Is it still the cable in those cases, or would it be more likely to be a gearbox problem?Can you hear the motor if the cable needs replacement?
you need the cable. check the previous post with the link to Volvospeed. it's a PITA, but if you need the back to work, it's worth the effort. luckily mine's stuck in a good spot!
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
