VOLVO S80 2.5T AWD 2005 ENGINE IS SHAKING
shorty20
Year and Model: s80 2.5t AWD 2005
Post by shorty20 »
HI .I have a problem with my Volvo .For example ,when I stop
on the read light ,I feel that the engine is shaking and I feel a ''massage'' thgrouugh my seat .That increases when clima is working .This is very irritating -mirror is shaking ,stearing wheel etc ..Please ,help me , Marek
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
My first guess would be that your brake rotors are warped or otherwise not flat. See this post: https://www.matthewsvolvosite.com/forums ... 11&t=13415
Do you mean it is shaking while you are stopping or after you are stopped?
shorty20
Post by shorty20 »
After ,but it doesn't look like- for example -like one cylinder is missing or something like that .It looks like the engine is not working smooth and it occurs when rpm is 700-800 .Marek
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Then it probably is missing.
Have you checked your trouble codes?
Have you ever changed out your spark plugs?
shorty20
Post by shorty20 »
Yes ,i have changed them .
There is nothing in trouble codes also .Car has only 72000km
Marek
MadeInJapan
What plugs did you use and what gaps?
Bosch Platinum plugs are known to cause problems
Gap should be 0.028 inches.
If not the plugs it could be a coil pack at the plug but then you should get a diagnostic code.
How about motor mounts? The upper one (round, above the engine) is it in good shape?
domaint
Year and Model: S80 2002
Post by domaint »
I just got a 2002 S80 with some minor problems and one was engine shaking. I checked the air filter and noticed it needed changing really bad. I did and the shaking disappeared maybe it will work for you. Good luck
shorty20
Post by shorty20 »
O.K. I will check the engine and the air filter .Marek
neworleans
Year and Model: 2007 S60R
Post by neworleans »
i would check the engine mounts as well...
harrr0
Year and Model: 1999 S80
Post by harrr0 »
A year ago, my engine was shaking when idling, it turned out to be my cam shaft sensor.
