Hi all, I'm a newbie and I have a 1998 S reg V40 1.9 td.
How do I knock off the daytime running lights?
NB I bought it cheap
Daytime running lights
Guest
From memory but i think its right...
turn ignition to pos2
switch light switch to side lights
pull main beam stalk & return key to position 0
let go of main beam stalk,
Alfonz.
Alfonz.
Guest
hmmm, i was sure that was correct, i'd just done mine ofter buying my T4
i'll check the handbook when i get ome.
alfonzobonzo
- Year and Model:
it says here, put light switch in side light position
switch ignition to position 2
pull main beam lever towards you
turn light switch to pos 0
ok.
ok.
480 L 1994 2.0 i Metalic Black K&N Panel
V40 W 2000 1.9 T4 Metalic Black
- 2355 Views
Last post by Liliflower
- 865 Views
Last post by Snaab
- 3485 Views
Last post by BEJinFbk
- 11 Replies
- 3013 Views
Last post by Faust
- 1286 Views
Last post by 93SCMax
