My power steering reservoir is low and I need to top it up. I purchased BARDAHL Synthentic Power Steering Fluid with Sealer and Conditioner. The bottle says that it is compatible with all power steering fluids and that it meets or exceeds all European and Asian manufacturer specifications.
Is there any problem mixing the synthetic power steering fluid with the existing OEM fluid still in the system?
Thanks, Kevin
2002 S60 AWD 190K kms
Power Steering Fluid 2002 S60 AWD 190K kms
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 26 times
My advice and this is from a non-professional is do not mix it. Here is what I know from personal experience. The manual says the power steering fluid is ATF, i.e. automatic transmission fluid, which is red in color. However, if you ask the dealer for P/S fluid he'll sell you a mineral based fluid, http://www.thepartsbin.com/catalog/?N=1 ... 63286+7177 that is green in color. I don't know whether this mineral based fluid is normal formulated power steering fluid and compatible with off-the-shelf P/S fluid and additives. So unless someone can confirm this for you I would not mix them.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I am always leary of mixing PS fluid- I would stick with what the dealer sells you and it will be slightly green in color.
Checksix
- Year and Model: V70 T5 2001
- Been thanked: 2 times
I wouldn't mix the fluids. The green stuff is Pentosin S11 of F11. Rather expensive and difficult to find, but FCP Groton carries it, but you won't find it on their web sight, but just call and ask. They have about the best price unless you find a local source to spare the shipping!
You will also need to find why you are low and fix it. After you pay the price for the Pentosin, you'll be more motivated!
Jerry
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
