A/C airflow vacuum motor failure??? '96 960
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
irbyjr
Year and Model: '96 960
Post by irbyjr »
A/C airflow reduced significantly when accelerating or hill climbing. Vacuum motors were replaced years ago but failed again. New motors are costly. Can the airflow regulator doors( :roll: ) be blocked open easily? Can this harm anything? If not, how to easily get to the doors??
Thanks a bunch,
Irby :roll:
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
irbyjr wrote:A/C airflow reduced significantly when accelerating or hill climbing. Vacuum motors were replaced years ago but failed again. New motors are costly. Can the airflow regulator doors( :roll: ) be blocked open easily? Can this harm anything? If not, how to easily get to the doors??
Thanks a bunch,
Irby :roll:
Maybe you have a vacuum leak somewhere else. When is the last time the vacuum hoses were replaced?
irbyjr
Post by irbyjr »
I don't think that the vacuum hoses have ever been replaced unless the dealer did that when replacing the vacuum motor years ago. I'll try to check them out.
Thanks
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Post by reverend »
It's usually the floor/defrost vacuum servo ("bellow" I think is the proper name) that fails. If you remove the cover under the dash, you can see it right above the gas pedal.
Most likely, it's the yellow vacuum connection that has failed, so you can unplug the yellow hose and cap it and you'll never have "floor only" but both floor/defrost and floor only will be floor/defrost. (the bellow has the yellow and I think grey hoses going to it - it's a push/pull configuration)
That's the cheap and easy fix.
The tougher fix is replacing that bellow. There are two ways, the proper way is to remove the dash and go in from above.
The quicker way is to cut a hole in the airbox and then patch it when you're done.
The bellow is $41 last time I checked (a few weeks ago).
Schumi 1
Year and Model: 1993 940 Estate
Post by Schumi 1 »
Hello,
If I am going in to replace the heater core, will I have access to replace the dual servo you spoke of ? wouldn't the floor/defrost setting engage the A/C ? or only when on defrost only. If I want heat to the floor , don't I have to replace the servo ?
