240 1993 ABS light and crimped line
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
240Dad
Year and Model: 240, 1993
Post by 240Dad »
Here is a photo of the left rear brake line from the junction that sits on top of the differential. If all else is well with my ABS system, do you think fixing this would make the light go out? I am assuming, since the sensors for ABS monitor wheel lock up and reduced flow of fluid to the caliper might affect that, that this might be the problem? By the way, I have no idea how this happened.
Thanks,
Bill
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It must have been quite a bump in the road to make the diff go that high. :roll:
If a fault develops in any part of the ABS, a warning light will usually be illuminated on the vehicle instrument panel, and the ABS will be disabled until the fault is rectified. In your case the valves which measure the hydraulic pressure will be reading very high pressure on that wheel and won't be able to reduce it - warning light comes on.
Hopefully replacing the brake line will solve the problem.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
