Sure has been a soggy summer
Anyway, I've noticed that sometimes when I start up the car after it has been raining out I will get the bulb failure light and the center brake light no longer functions. Bulb is only a couple months old, connections are clean, tight, and the light will return to working after a bit.
The same goes for my front left directional. Sometimes I will put on my signal to turn left and the relay is going 2x speed indicating a bulb out... I checked when it was doing this and it is the front.
Just curious if there's an earth ground or something that usually gets fouled when there's moisture, or something easy like that, before I go tearing apart the wiring?
Thanks for your help!
