1995 940 turbo accessing the A/C fan speed switch
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cquarts
Year and Model:
Post by cquarts »
Is there an easy way to access the rotating fan speed switch from under the bottom if the radio has been removed? if not, how much stuff has to be pulled off to get to it? Thanks Clay
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You shouldn't need to remove the radio.
Have your radio code handy and disconnect the battery negative lead. Remove the trim panel around the heater control unit to expose 4 or 6 screws. Remove the screws and lift the control panel upward and outward. Disconnect the electrical connectors.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
