2000 C70 top wont go down Topic is solved
servebig
Post by servebig »
Yesterday the top indicator was going off even thogh the top was down. Today neither the top or the trunk release works. I thought it was a fuse issue, but there doesn't seem to be a fuse for either, and all the fuses look ok.
any ideas?
servebig
Post by servebig »
someone at least tell me how i can disconect the thing that dings constantly...its driving me nuts :cry:
White850Turbo
Year and Model:
Post by White850Turbo »
There should be a relay under the driver's side kick panel that will disable the sound. As far as the rest of your problem, you may want to ask Rich (Bay13Admin) over in the maintenance section at Volvospeed.
Bronzite
Post by Bronzite »
I'm having an issue very similar to what you're describing. Did you find a solution?
Jot
Year and Model: C30 2010
Post by Jot »
Maybe you now know why Volvo discotinued the C in '04. The likely problem is one of the 6 motors that are needed to operate the top
