S90 1997 Fan starts when car starts
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tompete
Year and Model: S90 1997
Post by tompete »
fan starts and runs continuesly during operation of car. Fan continues to run for 5 minutes after engine is turned off then shuts off. Also temp guage jumps to 1/2 and fluctuates. Error code says eng temp LOW INPUT,PO117. What sensor may need to be replaced? and where is it located? PO410 is problem # two, Secondary air flow input. Is there a sensor to the air pump that would need changing? :(
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I moved you to the appropriate forum where you should be able to get more appropriate advice.
On an 850 I would say that you have a bad ECT sensor or a bad connection to it. On a S90 I'm not sure.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
P0117 is usually the engine coolant temperature sensor. It is mounted on the thermostat housing.
P0412, Volvo code 442, is a little harder to diagnose as it covers four different faults in the pulsed secondary air injection (PAIR) system. Checking the system with a Volvo scan tool would show a second fault code of either 446 or 448. The secondary code points directly to the problem. There is no sensor in the system but there is a solenoid which would not throw any of these three codes.
The attachment shows what tests can be done but you will be hindered by not knowing the secondary code:
S90 PAIR fault codes.pdf
(1.25 MiB) Downloaded 182 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
tompete
Post by tompete »
Thanxs for reply I will check as soon as possible.
OEMVolvoParts
Year and Model: ALL
Post by OEMVolvoParts »
AC fan relay 9442933 has been known to cause this issue, it is located next to the passenger side headlight. Mention MVS and receive free shipping from our page.
tompete
Post by tompete »
:D :) Thanxs all who helped.....Problems solved. sensor by thermostat was not making good connection at the connection, after cleaning it worked again. The other problem was a bad air hose to the air pump. I pinched it and it fell apart, it was the one about 3 inches long. Car is doing well. Thanx again for all your input :mrgreen: :lol:
