V70XC Oil Drain Plug Washer
PGFaini
Year and Model:
Post by PGFaini »
Should the oil drain plug washer be replaced with each oil change? Is the proper washer type flat copper, or crush-type aluminum? My Volvo dealer only stocks the flat copper one, and I'm concerned about stripping the threads on the aluminum oil pan. Is 26lb/ft the proper torque? Thanks.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Yes. The Haynes manual suggests 26ft.lbs of torque for the engine oil drain plug.
I use aluminum washers, and have been known to reuse the same one for two oil change cycles. Aluminum is the 'official' material for this.
FWIW, I have a magnetic drain plug, and have never found any metal filings etc. on it in ~2 years of use.
Also -> Amazon link
Volvord
Year and Model:
Post by Volvord »
The copper washers are used on the 200, 700, and 900 series Volvo with steel oil pans. You should replace the washer each time to reduce the chance of leaks, It is cheap insurance
Volvord 784VC
http://www.telusplanet.net/public/gilesij/Volvord/
genie
Year and Model:
Post by genie »
Definetely aluminum crush washer and yes, it should be changed every time you change oil.
