2000 s70 Idle drops low when coming to a stop
Gatekeeper21
Year and Model: s70 2000
Post by Gatekeeper21 »
This was not as big of a deal, but I just replaced the upper engine mount with a urethane bushing, so it makes the car shake. When slowing down, the idle drops to around 500 rpm rather than the normal of about 800-900. I have a manual shift, so this is happening when the clutch is depressed and not in gear. Once the car stops, the idle goes back to normal. It is just in the time that I am slowing down that the car idles rough. Any idea what may be causing this? This has caused my car to shut off a few times in the past (losing power steering around a corner at 30 mph is not fun).
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Could be a bad ETM.
See http://www.etmsettlementdocuments.com/2008/faq.html#Q2
Also see the Don's ETM Room forum on this site.
Gatekeeper21
I noticed today that it only seems to happen when the A/C is on. Is it just because of the load? Is there anything I can do about it?
BriAnNaXoXo
Year and Model: S80, 2009
Post by BriAnNaXoXo »
Gatekeeper21 wrote:This was not as big of a deal, but I just replaced the upper engine mount with a urethane bushing, so it makes the car shake. When slowing down in my volvo, the idle drops to around 500 rpm rather than the normal of about 800-900. I have a manual shift, so this is happening when the clutch is depressed and not in gear. Once the car stops, the idle goes back to normal. It is just in the time that I am slowing down that the car idles rough. Any idea what may be causing this? This has caused my car to shut off a few times in the past (losing power steering around a corner at 30 mph is not fun).
Sounds like the ECM. Even considering that it only happens when the AC is on but I'll admit that's strange. Take it in.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Could even be an issue with the alternator. That would explain why it only happens when the AC is on.
Warren561
Year and Model: 2000 S70 5sp Auto
Post by Warren561 »
I've had this same problem on my 2000 S70 NA for the past 10k miles. It seems to happen all the time. But, it is worse when the A/C is on.
It has completely stalled once because of it.
I chalk it up to a failing ETM.
I've taken it into the shop once, however they didn't do anything since there was no codes to pull. The service adviser simply attributed it to the age of the car. :(
FCPEURO
Post by FCPEURO »
I hate the ETMs on these cars. I will never buy a volvo from 99 to 02.
Brucebo
Year and Model: 850 '96, S70 '99
Has thanked: 3 times
Been thanked: 5 times
Post by Brucebo »
FCPGroton wrote:I hate the ETMs on these cars. I will never buy a volvo from 99 to 02.
So far with my XeMODex upgrade, it's better than new. I have about 10K miles on it now.
-Bruce
dongafish
Year and Model: S60, 2.5T - 2009
Post by dongafish »
Try cleaning just the throttle-body. Take the black, mass flow tube? off and clean around the outside of the butterfly valve and just inside.
2009 - S60, 2.5T - 69,000 miles
1999 - S70 - 215,000 miles
tom39
Year and Model: 2011 S80
Post by tom39 »
Sounds to me like its an idle air control valve. I had a Ford SHO that had the same symptoms. 15 min and $80 later that problem was solved. I never looked to see if Volvo uses them but I would think that they do. Maybe someone else can provide some further insite.
11 - S80 Silver 132k/mi
