94 850 NT, need help with heater Im COLD!!!
seamansteph
Year and Model:
Post by seamansteph »
I live in Atlanta & no its not always cold here but when it is I need my heater to work & lately its been crazy sometimes I get no air blowing at all after a few minutes, or I usually leave it on the hottest setting, I have dual climate control but when my son is in the car he likes to change it to a cooler setting rather than turn down the fan, he's 9 anyway when he changes the temp setting to a cooler temp., it blows out COLD air as if I had the a/c on, I turn it off & back on a few minutes later & its fine but it seems to only heat on the maximum temp. setting if at all Please Help!!
Jot
Year and Model: C30 2010
Post by Jot »
Most likely the thermostat is stuck open. it's an easy change BUT you will need a long torx driver to remove the housing. Most part stores will have it be sure that you have a new split O ring
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
Also -> Amazon link
