S80 2005 Seatbelt won't catch
DanV
Year and Model: S80 2005
Post by DanV »
Hi-- my rear seat driver's side (leftmost) seatbelt won't engage, i.e. it won't "click" in place, just falls back out. Any advice? thanks to all who try!
ps- mileage = 67k if it matters
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It isn't unknown for seat belt buckles to stop working. As they are a major safety item I would suggest that you replace the buckle. The rear seat cushion has to be removed to access the two bolts holding the buckle in place.
To remove the cushion lift the bottom edge of the end of the cushion then lift the front edge. It will be firmly attached so may take some lifting. When it is out check the retaining clips and replace any that appear damaged. Also check that the front edge of the cushion is straight.
When replacing the buckle the bolts must be tightened to 48nm.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
DanV
Post by DanV »
I will give it a go, thanks
dcarlson12
Year and Model: 1997 850 T5
Post by dcarlson12 »
Maybe a stupid question but have you looked inside the buckle mechaism? Perhaps a something has fallen inside it which is preventing the latch from 'closing'. Eg a coin or piece of paper or ???
OEMVolvoParts
Year and Model: ALL
Post by OEMVolvoParts »
Something must have made its way inside and damaged the latch. The Volvo part number for the left rear belt catch is 30780618.
DanV
Post by DanV »
Thanks for the advice, I did take a quick look inside and didn't see any obvious obstruction, but I do intend to take a much closer look... with 4 kids God knows what might have found its way into it. If I can't get it cleared I will go ahead and replace the part, thanks to all again.
