06 v70 2.5t p0017 error code, camshaft timing fix?
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
I would just remove any old timing marks by PO. Buy a new timing kit and start from scratch with instructions you find here in the forum. The tools you need are available for cheap on eBay. Mine is not the best quality but has been wotking fine for years.
BMW 540i 2002
S70 Base 2000
Psychotrashcan
- Year and Model: 2006 v70 2.5t
Did not. The intake hub was not removed during the process. Just the exhaust. So it's possible the exhaust hub was put back on incorrectly. However both were very close before I attempted to move it. The exhaust was slightly more advanced (by about 1 1/2 teeth) than the intake. May just adjust and see if that works?vtl wrote: 09 May 2022, 10:00 Did you redo the hubs? They are not notched and can be put on camshaft in any position.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
With DiCE+VIDA you can see precisely (fractions of degree) how bad is misalignment, actuate VVT solenoid, run VVT test and even see on the plot what is the actual VVT angle vs the one commanded by the engine computer.
Psychotrashcan
I fixed it. So apparently the exhaust hub was seated about 1 1/2 teeth off from its timing mark.
What I was not doing however was rotating the cams CW 90 degrees and then ccw back 90 degrees to their marks. Apparently not doing this caused it to throw the code. All is well now. Thanks guys.
- Has thanked: 1611 times
- Been thanked: 4072 times
Excellent
vtl
But this is not how the hub is seated.Psychotrashcan wrote: 09 May 2022, 14:38 What I was not doing however was rotating the cams CW 90 degrees and then ccw back 90 degrees to their marks.
The sprocket must be positioned in center (3 bolts are in center of oval holes), so it could be later moved left or right when doing the final alignment.
The hub is seated 90+ degrees CCW to the expected timing mark, the bolt is tightened slightly, the hub is then rotated CW until the mark is met. The bolt is fully tightened then. At this point the hub should not move CW past the mark, at least not very far. It will be off a few degrees, but the sprocket alignment can compensate that.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Can't beat success.Psychotrashcan wrote: 09 May 2022, 14:38 I fixed it. So apparently the exhaust hub was seated about 1 1/2 teeth off from its timing mark.
Last time I went down this rabbit hole I think I had the belt off and on 12 times before I got it right. Documented it inthe Elizabeth maintenance thread.
SVO LOU
- Year and Model: 04 XC70, 06 V70
- Has thanked: 44 times
- Been thanked: 5 times
I know this is an old thread but I'm having similar issues on an 06 v70 2.5t and would like to read through that Elizabeth thread, can someone pinpoint it for me? Searches for that do not come up with what I'm thinking it would be. Thanksabscate wrote: 11 May 2022, 03:37 Last time I went down this rabbit hole I think I had the belt off and on 12 times before I got it right. Documented it inthe Elizabeth maintenance thread.
01, 02, 04 XC70, 06 V70
- 5238 Views
Last post by Goldchemist
- 909 Views
Last post by jmartin919
- 1664 Views
Last post by volvolugnut
- 11 Replies
- 2783 Views
Last post by bmdubya1198
- 772 Views
Last post by KevinCro
