Sticker shock: motor mounts
jkatz
Year and Model: 2007 XC70 2.5T
Has thanked: 2 times
Been thanked: 6 times
Post by jkatz »
abscate wrote: 18 Sep 2022, 04:52 I think there is a lot more engineering in that mount than I appreciated before. The aftermarkets just fill the metal with a glob of polymer and then you get massive transmission of vibration direct to the front windshield cowl
The OE version, the rubber is not fit or bonded to the metal, the torque is transferred from the friction of the side of the rubber to center bolt. I bet the damping effect of that is huge and important
I did not appreciate this feature until now. I assumed the rubber in OE version was bonded to the housing and I was disappointed that my cheap Uro (actually “Anchor”) one was not, and so I experimented by filling the gap with epoxy which ended exactly as you describe, with a shaking dash.
What I find confusing is that the underside of the engine appears perfectly still while the upper mount apparently needs to allow a full 1cm of fore-aft movement. My mind wants to picture the engine pivoting around a geometric center, when I guess it really pivots much lower, like the crankshaft region. Of course now that I wrote it that seems obvious and not at all confusing.
2007 XC70 174k mi
2003 V70 NA ('gifted' to family)
[[ 8 years of Toyota ownership ]]
1984 245 B21FT (sold, 250k mi)
1980 245 B19 (scrapped, 450k mi)
Has thanked: 1609 times
Been thanked: 4063 times
I just had one in my hand from the T5 valve job and there is a lot going on there.
