Paul and ChitownV ,
I am not dissing anybody’s info. All is very much appreciated and I do my best to learn as much as I can. I am not a young person and sometimes it takes a little time for me to wrap my brain around a new concept which this vvt vs vvl is.
Thanks, Ruth
2007 XC90 3.2… cem not communicating with rem?
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
I’m glad you were able to diagnose and fix the problem with the REM. The cam profile switching, I’ve never had to change that on my 3.2. I’ve changed solenoids, cleaned solenoids, and replaced seals on other Volvo engines and non-Volvo engines, but with proper oil maintenance, mine has never needed it.
Good luck with the rest of your repairs and happy motoring
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
ERO1
- Year and Model: 1996 850GLT ; 2007 X
- Been thanked: 2 times
I took it to a guy who knows imports pretty well and all he said was it has variable valve timing and that an oil change might help.
I got this car a year ago for 500.00.130,000 miles .Put new tires on it and went from Virginia to Illinois and back without a minutes trouble. Only codes have to do with the steering angle sensor which I plan to take care of as soon as I get this other issue figured out.
I bought a Volvo dedicated scanner from icarsoft and it gives a lot of information (more than I understand at the moment)…still learning.
I went to town earlier which is about 14 miles. I cleared all codes before I left and checked when I got there. I had some misfires on #4. The car ran great at speeds 55+ but had trouble with lower speeds.
Coming home I put the cruise on. It did ok until it needed extra power like up a hill. (I live in western Virginia so lots of those)
Then it bogged down, but ran great over 55…it also threw a bunch of codes when it bogged down…. Misfire on 1,2,4 and random misfire code. Same cam profile solenoid code as before and catalyst below threshold bank 1 and 2. Thing is I can clear those codes and the only one that comes back is the camshaft solenoid and or maybe misfire on cylinder 4 unless I really stress it.
Any input welcome .
Thanks,Ruth
Any input welcome .
Thanks,Ruth
White 1996 850GLT first Volvo.... loving it!
Magic Blue 2007 XC90
ERO1
Forgot to mention, while driving was getting flashing cel but got home ,restarted engine,light gone….?
chitownV
Well, as mentioned already, try replacing the solenoids and see what codes pop up after. They can be tested with a 12V source like if you ran wires from a Milwaukee M12 battery. Sometimes a 9V battery is enough to trigger the solenoids. They can can get clogged with carbon and junk from the oil over time too, which may the reason you need to change them since you may not be entirely sure of the oil change history the first 130k miles.
Btw, I’m in the DMV area so not too far from you. The cam profile switching would definitely occur for uphill driving, especially after a transmission kick down and the engine pushes to higher rpms.
ERO1
I’m sorry I’m so dumb but here is a pic of the passenger side, bank1, of my engine. I’m trying to match it to Paul’s photo on the link you gave me. Where is the solenoid? I know you said under the motor mount but I don’t see the bracket mentioned..?? Idk… please help… be kind
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
That's the variable valve lift solenoid (round top) The rectangle top next to it is #1 ignition coil.
On my P3 the motor mount bracket gets in the way of removal but on your P2 it look like you can just remove it.
The motor mounts are different for P2 and P3.
That makes it easier to fix just the one Torx Bolt and the electrical connector to disconnect.
Warning!!! Warning!!! Warning!!!
NOT P2 CONTENT
NOT XC90 CONTENT
NOT P2 CONTENT
NOT XC90 CONTENT
- Been thanked: 4071 times
Ruth, have you put a fresh set of spark plugs in this thing yet? The coils also do give up the ghosts at 100-150k miles
ERO1
Abscate, the shop said that they had pulled and checked the plugs. I had ordered a new coil for the #5 that was missing at the time I took it in but they claimed they checked those also. However I don’t know what they did with the new coil. I have ordered new cam solenoids but I don’t know if that will fix the problem. There seems to be some back pressure as the plug off of the bank one solenoid is full of oil. The solenoid does seem to be bad.
Solenoids should be here the end of the week. I will report after installing those , doing a PCV check . I hope it doesn’t turn out to be the catalytic converter!
Thanks, Ruth
Thanks, Ruth
ERO1
Update: replaced the vvt solenoid on bank 1. No more bogging out under load .Replaced the coil on #4 which was missing. Car runs like a dream now. Next project is the “anti skid service required “ Thanks for all the input/help! MVS is the best!
- 1399 Views
Last post by Roger_850T
- 2506 Views
Last post by precopster
- 22217 Views
Last post by ggleavitt
- 2107 Views
Last post by yagger
- 11 Replies
- 3224 Views
Last post by deano1
