Yes. Is the last one the picture you were talking about?abscate wrote: ↑09 Nov 2022, 00:01Pat, did you see pix in this thread?
viewtopic.php?p=603537&hilit=1999+dash+trim#p603537
Dash Trim Noise
- patcal
- Has thanked: 99 times
- Been thanked: 10 times
Re: Dash Trim Noise
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Dash removal isn't that bad. It’s the mounts in the back that break. Checkout Robert’s (rspi) youtube video explaining what to do. It’s easier than it sounds and it’s a one man job. I must have done 3 or 4 by now, all on S70s. It’s a good feeling when you finally get the dash to quiet down.
Give it a shot and good luck!
oh, and if you have a shiny shifter, put a sock on it so it doesn’t get scratched. Or just remove it.
BMW 540i 2002
S70 Base 2000
- Has thanked: 1506 times
- Been thanked: 3818 times
patcal wrote: ↑09 Nov 2022, 05:07Yes. Is the last one the picture you were talking about?abscate wrote: ↑09 Nov 2022, 00:01Pat, did you see pix in this thread?
That’s right. I can grab a better one if needed. Have a console trim piece out of car.
- patcal
No I think that will be ok. Do you have a picture of the side of the trim? Kind of showing how it meets up to the dash itself. That might be helpful. Thanks. I really appreciate your help.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- patcal
Thanks for the response. I am pretty sure the firewall mounts are fine. I can tighten them down ok. The noise does not change when I push on the dash but when I push on the climate control/stereo surround, where I showed in the picture.kallekula wrote: ↑09 Nov 2022, 05:18 Dash removal isn't that bad. It’s the mounts in the back that break. Checkout Robert’s (rspi) youtube video explaining what to do. It’s easier than it sounds and it’s a one man job. I must have done 3 or 4 by now, all on S70s. It’s a good feeling when you finally get the dash to quiet down.
Give it a shot and good luck!oh, and if you have a shiny shifter, put a sock on it so it doesn’t get scratched. Or just remove it.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- kallekula
Yeah then use butyl rope, cardboard, credit cards or whatever that works. I’m pretty sure the firewall mounts are not ok. You have a 98 S70 right?
BMW 540i 2002
S70 Base 2000
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
+1 on what kallekula said. Rarely are they in good condition, at least one or two are usually broken
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
.patcal wrote: ↑06 Nov 2022, 06:44 Greetings all,
I have a very squeaky dash in my 98 S70. It is not the dash mounts though. At least I do not think so. All 4 mounts are tight in the dash & the dash itself seems tight. I am getting the noise in the trim where the wood trim around the stereo & climate control meets the dash. I am probably not explaining it well. I am attaching a photo the points out where the noise is coming from. All along both sides where the arrows points to. I can push on the dash itself & the noise does not change but when I push the wood trim, I can get it to stop. I do nothing that this trim can be removed without pulling the dash. Any thoughts on this? One final thing. This is an older photo. When I recently changed my head unit, the noise got a little better for a while but it is still bad. Thanks.
For the face plate trim area try some cloth tape.
Tesa 51608, 15m X 19mm Adhesive Wiring Loom Cloth Tape
(www.amazon.com/Original-Wiring-Harness- ... 830&sr=8-6)
