XC90 2.5T 2004 No spark cylinder 1
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Dragoz001 wrote: 19 Nov 2022, 09:18 Er... CEM-B sounds like Chinese to me... yet I guess it's a generation that has some PIN protection in case you want to program it from the ODB2 plug. Am I correct? I have a Chinese DiCE unit.
CEM-Brick the brick shaped CEMs used in 1999 - 2004 P2s. Best name I could come up with for that generation of CEMs. The CEM is protected against change by a six byte PIN number. It is the one CEM that we never been able to crack over the CAN bus.
Did you check the wiring to coil #1 for shorts ? A short could take out an I/O port.
Active
Past
Dragoz001
Year and Model: Xc90 2004
Post by Dragoz001 »
Thanks for the explanation.
Yes I checked the wire for short circuit.
Dragoz001
Post by Dragoz001 »
Hi,
I finally can post some update on that problem!
I ordered a used ECM fom eBay. The donor car was exactly the same as mine, released a few months later.
I managed to find someone to clone my ECM into the one I bought. It took 2 weeks to send it and get it back...
The engine started with the new ECM but it was stuttering, black smoke and when I pushed the throttle it almost stalled.
I checked the cylinder #1 spark plug and could see that I now have sparks! So the original problem is fixed at least!
Important to mention here that I had E85 in the tank. The car got reprogrammed for E85 by the previous owner.
He gave me a small device that I can plug into the OBD2 socket and I have a menu to get back to the original setting or program the MF setting (Multi-fuel for E85).
So I decided to redo the MF programming. I could do it successfully even though the small device was set to work only with one ECM (serial number check or something like that).
I also did a reset procedure that I read somewhere (unplug the battery for 1 hours with + and - connected).
After that the problem seems fixed! The engine seems to run well (I ran it only a few minutes because it was late).
Today I will plug the VIDA to erase the DTC and see if some codes come again after a try on the road.
So it seems that the "cloning" does not copy all data from the 1st ECM to the second. At least it's my interpretation...
Dragoz001
Post by Dragoz001 »
For those interested I have some news about my problem.
The ECM works well actually.
I have found a second problem on the car!
There was a vacuum leak at the intake manifold gasket on cylinder 1 !
Dragoz001
Post by Dragoz001 »
Last update in case it may help someone in the future.
The car now works perfectly!
Smooth idle, good power and MPG increased drastically (from 18 l/100km to about 13).
Basically I had 2 problems:
- 1 recent was that the ECM failed (output for cyl #1) and had to be replaced
- the 2nd was older (I saw several invoices of the former owner mentioning rough idle, lack of power, etc.) and was a vacuum leak at the intake manifold gasket next to cylinder #1. The leftmost screw of the manifold is a bit hard to reach and was not tighten enough. Probably the cause...
Thanks again to RickHaleParker who took time to help me.
