CEM-Brick the brick shaped CEMs used in 1999 - 2004 P2s. Best name I could come up with for that generation of CEMs. The CEM is protected against change by a six byte PIN number. It is the one CEM that we never been able to crack over the CAN bus.Dragoz001 wrote: 19 Nov 2022, 09:18 Er... CEM-B sounds like Chinese to me... yet I guess it's a generation that has some PIN protection in case you want to program it from the ODB2 plug. Am I correct? I have a Chinese DiCE unit.
Did you check the wiring to coil #1 for shorts ? A short could take out an I/O port.
